I just removed the oil pan. Had no trouble with any of the bolts. Soaked them plenty in blaster. I knew I had to remove 14 bolts, cause that's what's shown in the Helms manual. However.....
I had to remove one more bolt not shown in Helms, namely a bolt that secures the pan to the transmission housing. The bolt is a 10mm x 1.5 and about 1" long thread.
There are actually two holes in the pan. Thus probably two bolts are needed. But there was only one bolt on my car. (I'm speculating that the other bolt has been lost by accident or during dealer service when replacing the clutch.)
I'm curious about these two bolts. I can't find any reference to them in the Helms manual. And it's weird, since one can NOT remove the pan, nor the xmission housing, without removing these two bolts.
Do any of you know if these bolts go in before or after securing the pan to the cylinder block?
And do any of you know the torque specs for these bolts?
Michael
Michael
