Oil Leak
gbizzle27
Bradford, Pa
I was under my Sho today and i noticed oil all over the bottom of the oil pan. Looked it over real quick but didn't see anything. I then checked the oil level and noticed i have lost a half quart of oil over the past 600 miles. Any idea's of where the oil leak could be comming from?
Sho-Driver
Peter Pan
The Garage.
Is it coming down from the accessory side of the motor? If so, it is most likely cam seals and/or front main. If it is coming from the rear or front of the motor (in relation to the car), it may be leaky valve cover seals.
fastindy
Rochester, MN
Similar problem on my 90. I looked tonight, found a sending unit on the back side of the engine was leaking. Now to figure out which sending unit it is and how hard to replace.
Sho-Driver
Peter Pan
The Garage.
Is it on the back side of the block or oil pan? The one on the block is the oil pressure, the one on the pan is oil level.
