oil in plug wells
shocrazy
Douglassville PA.
HI i just bought another 92 sho last week and there is oil in the plug wells. what does this mean? how hard is it to fix? and how expensive is it? if someone could answer those 3 ?s for me i would gratly apretiate it
stangeater
Farm Boy
You need oil well gaskets......they're not that expeisive, and they're pretty easy to install!! Take the valve covers off, and you'll see them! Good luck!
Ishodu
Usually a good sig that the 60K maintenance was not done. If you try a search on 60k I am sure you can read for hours. And you will find the info you need right away also.
platoribs
Live to Drive
Plat0ribs House of SHO,il
One of the best write up's (with pictures and arrows to illustrate motion) on removing the intake and R&R of the valve cover gaskets and plug well seals can be found at SHOpheonixproject.com.
autobahnsho
SHO Victim
NY for now, WY for real
Check your wires!
My wells were completely full of oil. When i sucked the oil out and put new seals/ plugs in, it missed like crazy, since 4 of the wires were completely cracked. Apparently the oil kept them from arcing... :nut:
New wires fixed THAT problem....
