Oil Gauge
Izzmo
SHO Enthusiast
Kansas City, KS
How hard is it to install an oil gauge for the genIII? I have an offer to buy one and it's almost too good to pass up! So, just needed this general info, hopefully it isn't too bad.
NebraskaSHO
Harumph!
Omaha
What kind is it? My guess would be a T fitting at the PSI sensor.
Yes you need a short 1/4" NPT brass ****** and a 1/4" NPT tee. Then just take the OEM sender out, inset the ****** and tee and the connect both senders to the tee. It's important to use a brass pipe as this will help to prevent the stripping out of the threads in the aluminum block. Be sure to use some sort of pipe thread sealant, preferably a semi-liquid type vs the tape.
NebraskaSHO
Harumph!
Omaha
Those fittings are what I used on my 318 Small Block Mopar when I installed a mech. oil psi gauge.
