Oil Drain Bolt
TYSHO
Earth
but its a matter of getting it to turn that I'm having problems with and I am put some big time force onto it.
Hit the end of a rachet with a damn hammer and be done with it unless you done stripped the thing trying to do it with vise grips. That was a stupid move because vise grips can't get a full grip on the bolt head and are easy to slip off and strip away the bolt head. You're making things harder than they actually are. I can take a rachet and hammer and remove lug nuts torqued to 150lbs, much less an oil pan bolt.
Storm-Chaser
Shit Louis
I'll have to see if I can find the reciept the P/O gave me. So you saying I should drive it out to that place?
This bolt defiantley isn't moving.
You may also be able to get a copy of the charge from your credit card issuer, if you paid with a cc.
If the vehicle is driveable, I sure would take it back. Why should you have to pay for repairs or live with an oil pan they damaged/ruined? They might even try to hide the prior damage by repairing it without notifying you !
Until that bolt is removed, it is obvious "who" improperly installed the bolt and damaged your oil pan as a result. Once it's removed, they can claim anyone cross-threaded the bolt, including yourself.
Nrw7
Oil change kid
Worcester,Ma
Its done I finnally got it off. If Kirk sees this he'll probally tell you the whole long embrassing story.
TYSHO
Earth
What, you were turning the wrong way or were trying to remove something other than the oil pan bolt?
Nrw7
Oil change kid
Worcester,Ma
No it was after that. I really don't want to talk about it right now, maybe later.
Nrw7
Oil change kid
Worcester,Ma
Jeez you guys have good memories I thought I would get away with out telling the story. But lets just say that the amount of oil that was supposed to be put in was a "little" to much.:oops:
Mr Anonymous
Tire Wall
I've decided I'm saving the story for the convention, so if you want to hear it, you'll have to show up in Kalamazoo! :thumb:
Nrw7
Oil change kid
Worcester,Ma
Oooo so say it when I'm not around.lol. Yea I don't know what the **** I was thinking. and 22 was the total amountof oil I used.:nut:
TYSHO
Earth
Wow...that's amazing if you didn't blow any oil seals! :oogle: I can imagine the look on the face of whoever removed the oil pan bolt and was waiting for the oil to stop pouring, and/or had to stop the flow and grab another drain pan! :rofl:
That happened to me on an old Torino I had. I had to keep adding tranny fluid and could not figure out where it was going.
One day the engine started gurgling and I checked the oil. It was way up the dipstick. It had all been sucked up through a bad vacuum modulator. I bet there was 5 gallons in the engine.
Ran good after the cleaning though. :)
Nrw7
Oil change kid
Worcester,Ma
Oh that was the easy part I just needed the right size easy out, which the damn kit I bought didn't come with.
