Oil Consumption
Midwest
Wondering how much oil ya'lls motor eats.
Mine's at 1/2 to 3/4 quart every oil change (@2,500 to 3,500 miles).
What's normal for the yamahammer?
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Up to 1 qt. between changes is pretty normal. Every SHO I've owned has used a little bit between changes, even our 93 ATX we bought new.
HopefulSHO
Bellevue, NE
My '94 MTX ate a quart every 800 miles. Ran like a bat out of **** too.
The ATX eats about a quart every 2500-3000.
My engine rolled for the first 100,000 miles without burning/leaking more than 1/2 quart every 3,000 miles (my standard oil change interval). Over the next 125,000 miles, the oil useage varied from the 1/2 quart number to as much as 2 quarts during the oil change interval. The predominant path for oil departure from the engine was the various leak paths that were addressed during the 60K services.
The oil use increased gradually over the next 60,000 miles as the rings and seals aged. I was adding as much as a quart every 800-1000 miles. All of the cam seals were leaking and the greatest leakage path was the rear exhaust camshaft seal. After replacing the camshaft seals during the 60K service at 269,000 miles, the oil leakage was reduced to nearly zero and I no longer needed a catch tarp beneath the engine when parked in my garage.
With no evidence of significant external oil leakage, my seasoned SHO engine now consumes about 1.5 quarts during the 3,000 mile oil change interval. That comes out to about 1/2 quart every 1,000 miles. Quite good for an engine with nearly 300,000 miles and even acceptable for a brand new powerplant.
masho95
got Zex?
Chicopee, MA
I seem to lose about 1 quart of oil per 3K miles between oil changes. 103K miles on the motor.
nc89sho
S13 Sellout
Clemmons NC
not to brag or anything, but my atx uses almost NO oil at all. the only time i ever put oil in it is when i change it. the 89 on the other hand....well. let's just say it's gonna be engine time for that thing pretty soon.
revhardSHO
Seattle, WA
.5 quart over 1000 miles on the new 94 atx (I havent changed the oil yet).
2.0-2.5 q over 4000 miles on the 205K 89. Both main seals are leaking, and the rest is blowby from the various warn internal engine components - but she's still the fastest SHO in the stable! :shrug:
Blue-By-U
CT
Depending on how hard I drive my SHO oil consumption varies from 1/2 to 1 quart per 1000 miles.
