Has anybody thought of creating something, like a plastic or fiberglass shield, that molds around the starter in an effort to shield it from oil that drips during oil changes?
I challenge all out there to come up with a design. I'll buy one.
It would seem easy to design...simply mold it around the starter and use one of the starter bolts to fasten it. Make it with a curved ****** that goes up towards the engine block until it finally meets it, creating a "wall" at the top that extends downward towards the front half of the subframe.
The bottom half would be molded in such a way to divert the oil from the leaking filter toward the front of the subframe. The oil typically drips towards the back of the subframe, on the side closer to the rear, and always splatters all over. It would be nice to sheild all the wiring from the oil as well. Maybe the bottom part of the shield can be "funnelled" near the end of the shield in order to direct the oil into one predictable exit point?
There's no way to change oil in a SHO without getting at least SOME of it all over...unless you have somebody else do it.
Damn starter!
Damn starter!
