That's pretty bad. How Many miles? You might want to pull it apart, clean it up, and see if the other runners are as gunked up and see if there is a sealing issue there. Maybe there is an oil leak nearby and it's getting burned and condensing there??? I recall seeing that kind of mess on other areas of dirty engines that drip and burn oil. Or maybe oil vapor leaked around those locations as well??
