autobahnsho
SHO Victim
Blow Head Gasket? (formerly oil and smoke)
I already posted this @ the shophoenix site. Thanks JD for the response:
OK, so in January I sucked the oil out of the spark plug wells (the plugs were totally immersed), put new valve cover and plug well seals on.
Car started running like crap. Like 2-3 cylinders were missing. The plug wires were cracked, see
photoisland.com
login id autobahnsho
password sho
for some pictures of the mess. I replaced them about a month later (I had to save the money.)
This month I replaced the cam seals, since I had oil dripping from one of them. I messed up the front bank, so drove it leaking massive oil for about a week and a half. LOL- I had to put a drippan under it at night, which collected a cup or two, and I went through 2 qts. of oil during that time. I got it replaced last Friday.
Saturday I was driving and I put the clutch in to coast to a stop off the highway, engine died. I put it in third and pop-started it, then a few lights later the idle was really low (maybe 200 rpms lower than usual) and the RED oil light was flickering. I also heard some knocking, like a diesel engine or something. I revved it up and it went away, but a few moments later it came on SOLID, with the CEL. I pulled over and stopped. Checked the oil level and it was FINE. There was SMOKE coming out of the dipstick tube- burnt oil. Re-started and haven't seen the oil light again.
Now I'm also seeing a lot of smoke (whitish) out of the exhaust almost all the time. It might have been happening before last week, but I didn't notice it.
There is a 'tapping' sound coming from the engine- in all the work I've done the valve lash hasn't been checked yet. It sounds like it's coming from the top, but I'm not for sure it's not coming from the bottom of the engine.
I was low on oil today and added a quart, there was also smoke coming out of the add oil hole.
I think the motor's on the original rod bearings. I want to replace them ASAP. Do you think I 'spun' one already? It still drives fine.
What's causing the smoke in the exhaust? Price to fix??
Registration is due May 5, I have to buy new rear tires and clean all the oil off the underside to prove it doesn't leak now. Am I going to buy tires only to have the engine blow up in the next few months??
Thanks for any ideas or help,
photoisland.com
password sho
