Odometer issues
MikesSHO
My odometer has been giving me issues for awhile now since about 75k I'm now at 107k. It's like there's a bad connection but I have no idea where to start at trying to fix the issue. If I tap the dash above the odometer it lights up perfectly.. Any help would be appreciated
Sounds like replacement of the Instrument Panel Cluster (IPC) is required to fix this issue. The dealer can help with replacing the lights as well per the manual. You can pull fuses to see if that helps any.
Fuses 26,29 in the passenger compartment fuse panel relate to the IPC on the 2010.
Fuse 23 for the 2013.
