odd stalling
meryan00
Indiana
I have a '92 GL which seems to have an odd stalling problem. When my engine is cold before it heats up it will stall if i hit the accelerator in gear, in neutral there is no problem. I had a ford dealarship look at it while they replaced a motormount and half-shaft assembly and they told me it was a throttle positioning sensor, I tried replacing that and it still has the problem...hopefully one of you can help me with this issue
SHO#7
Cincinnati
You will find more help at www.taurusclub.com
Over here, we know more about the SHO engine. Which is a very different beast. Aside from that, I would start with checking codes, cleaning your MAF, and maybe the IAC valve.
Mike
