Odb-ii
93rev2sev
Hockeytown
Has anyone looked into converting the v6 to ODB2?
Is it even possible? Seems like there are a lot of plug and play tuning devices for ODB2 vehicles.
Phoenix
SHOHOLIC
QC , Canada
OMG that would make my ATX-MTX conversion (with MTX ecu/harness in a atx car) look like childplay.
But anything's possible , got time?
I would start with a duratech wirering with a tuner...
Right off the bat you need 4 o2's....
Converting signals , crank sensor /cam /knock..
Challenging? More then anything most have ever done.
93rev2sev
Hockeytown
I imagine it would not be easy...but ODB2 has a lot more flexibility than it's predicessor; so it might not be as hard ... especially on an MTX ... as you think...but I have no idea what a headache it would turn into...probably a big one.
firstgen89sho
former Slo_SHO
Lloydminster Sk, Canada
I had thought about it myself..... I would have thought that a Vulcan processor would be easier..... being a coil pack vs COP, and being that you can get a vulcan proc in a MTX form
ATX/MTX again is no problem with a tuner. COPS can be used on the V6 SHO IIRC. Doesn't some one have this?
Duratec would be the better setup with a coil pack. Some Vulcans don't use a KS.
hawkeye18
Sorta cares
Norfolk, VA
Making an OBD1 car an OBDII car is kind of like making russia a democracy. Technically possible, but highly unlikely.
firstgen89sho
former Slo_SHO
for those who are electronically adapt, it's not that hard.... most sensors are the same, injectors and such, it's just a bit of wiring involved, once that is in, then it's just the ECM programming.
