OD out on ATX - Any ideas?
ml98188
Seattle
Car - 94 ATX - 111K miles
Symptoms: OD cut in and out intermittently for a while - popped out of OD
on cruise- hitting the switch would get it back. Then the switch
would work sometimes - then not at all. Had the trans
serviced - seemed to help a little but now OD is totally failed.
The rest of the trans shifts OK.
I've had the car parked for a whilefor various reasons but now I'm getting ready to put it back on the road.
Anyone have any ideas other than outright rebuild?
93superSHO
Thats a Taurus?
Minnesota
If the rest of the tranny is working as it should, I would bet you have a broken C-clip for the O/D servo. It is a simple fix(cost less than $1) Take the driver tire off, the O/D servo cover is the one located( dvr side along the firewall, down low by the PS rack, take the 3- 8mm bolts off and you will see the you have broken the c-clip that sits right there. replace it and you got O/D again. get the broken one out of the tranny. While you there you might as well replace the fluid/filter if it has been awhile. :thumb: :cheers:
I believe there is a thread on shotimes.com about this. ;)
ohfosho
ontario SHOwner
ontario, canada
theres a slight chance it could be the wiring for the o/d button in the shifter too, but most likely the c-clip there.
ml98188
Seattle
:thumb: Now those are the kind of fixes I like. (cheap ones) Thanks guys. As soon as I get the Jeep out of the garage this afternoon I'll get 'er back in and take a look.
Stay tuned....
