O2 part #
bigsho
sterling va usa
One of my O2 sensors is bad. So I went to ford to get new ones. They said there are 2 types. One is $40 and the other is $60. Which one do I need for a 95 mtx. Thanks
Robbie
95 MTX red
SS SNORKEL
24 and 26 sway bars on floor
fredhurderjr
www.neshospecialists.com
You use one of each - F0SZ-9F472-A ($65 list)& F03Z-9F472-A ($80 list). SHO Nut (www.shonutperformance.com) has both for about $48 each.
White 95 SHO MTX
"Jezebel"
Spends more time in the shop than in the driveway
Teases me with occasional great runs
3.2L SHO Shop Long Block
9psi Vortech S-Trim Supercharger (12psi on the way)
Eibachs, Tokicos, 96 Brakes, SFCs, STBs
PP Y-Pipe, Custom Stainless Cat-back, Bullets
http://members.home.com/fhurderjr/sho.htm
Mocha 91 SHO
"Monique"
S
slosho
Guest
What's the difference between the two and which one goes where? This is the first I heard of this.
95' ATX Opal Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a "PCV" line
Fog light mod
Reverse light mod
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
bigsho
sterling va usa
Thats a good point. I need bank 2(right)_ the one off the front 3 cyls.
Robbie
95 MTX red
SS SNORKEL
[This message has been edited by bigsho (edited 11-12-2001).]
DeaconBlue
Cleveland, Ohio
The only difference is the length of the 3 wire leads out the back side of the O2 sensor. I ended up replacing mine with Bosch unit this summer. I used two with the same 6-1/2" length wire leads. Can't remember the p/n, but they were about $38 each at AutoZone.
95 MTX
with a few mods
fredhurderjr
Deacon -
The design of each is different as well, at least mine were when I took them off my 95's. One is longer & thinner (not the connector, the sensor itself). I think it goes by the casting number on the exhaust manifold. Not sure, though.
