Now what?
Vito117
Iowa
I just replaced my A/C clutch( what a *****#@&%)
A/c is working again.
I still have that damn idle problem.
I have a CE light on.
I ran the codes....and it indicated a ignition coil problem. Wll this cause my stalls that I keep haing after car is warmed up? I did replace plugs in August but did not replace the wires.
My codes #s:
117
217
618
621
So what should I try next?
You have several electrical problems:
117 ECT sensor is/was low or grounded
217 Primary circuit failure - ignition coil 3
618 Transmission shift failure (2/3 shift)
621 Solenoid/circuit failure - shift solenoid 1
If these failures have all showed up after a single causal event, you need to determine what the event was and go from there. Have you recently washed the engine compartment with water?
Vito117
Iowa
I remeber washing it about 6 months ago......I know its No No.
Could this have caused it?
Replace ig coil and plugs?
