doclees
Ok here we go again with a mystery noise on the 93 ATX. You know the old Stooges movies where they are driving down the road and parts are being left in the road behind them? Well it kinda sounds like that without the parts falling. I step on the break normal and I feel a little tight wobble because of warped rotors(I think). Then as I slow to a stop I get more peddle surge and a sound like the calipers are flopping around with a grinding sound. Or like a bad CV joint. Drives great. Corners great. Pulled the tires and brakes look good. No obvious wobble in front end parts. Noting strange with rotating the shafts back and forth. The only thing that I can see might be odd is on one rotor the play in the lug nut stud holes allows for about 3-4 degs play. Could I be just not torquing the lugs on enough?
