Not your usual oil light question
tauruswithheart
CT
first off my car has 69k miles on the clock, i did valve cover gaskets and plug well seals and new plugs and intake gaskets......timing belt, water pump, cps next......anyways......its a 90 mtx, waterpump is original and not leaking.....the car starts right up but seems to idle VERY low..like 600 or so....the car has plenty of nut and the oil light didnt come on at 1700 in 4th gear when i floored it(i know its bad but you can hear the knock of bad rod bearings that way and you sometimes see the oil light flicker but i have none of that).....MY MAIN QUESTION is why in the heck does my rpms drop so low that the oil light coms on then adjusts it self to the still low idle? it happens when i press the clutch pedel coming to a stop only its weird.....O2 sensors-iac/b? i have NO engine codes just an abs code because i broke one of the sensors doing my tokico/moogs
