wild01ride
Back in time...
OK, so recently my '98 has developed a hella crappy idle. Basically, the idle is REALLY erratic between 500-1000RPM. It's so bad the car shakes like a ***** when idling. The problem is also noticeable at speed with very low throttle position. You can literally feel the car surging while cruising at a constant speed while applying small amounts of throttle.
I've gone through the high idle thing before and conquered it, so I'm familiar with that. Naturally I thought I was having an IAC issue. I took the IAC off, cleaned it and put it back together- still no good!
OK, so I know everyone's already half done typing a repsonse about coils, yada, yada, yada... but wait!
At any higher throttle position, the thing runs like a ***** ape- as good as it has ever run. I mean, it's STRONG- and absolutely smooth as butter too, no surging, no hesitation, NOTHING.
So, I don't know if it could still be a faulty IAC or not. I wouldn't imagine that the IAC would cause problems at partial throttle settings, but maybe so. The other jacked up thing is that sometimes it'll idle without any problem. WTF?!?!
Oh, and then there's some kind of burning smell going on- smells like burning rubber (PS belt??), but smells like it's coming from between the engine and firewall. It gets pretty bad when stopped for a long time.
Any thoughts would be greatly appreciated!
Mr. Anonymous, SHOZ123, & Ian Macoomb!
