not starting
gbizzle27
Bradford, Pa
Put a new motor in my car and got it started up, then the timing belt tensioner broke. Fixed that and sense then i have no spark. I changed out the DIS and CPS and nothing worked. There are no codes other then 519. Anyone with any idea's??? I am confused?
SeanMc
NoMoSHO
Hmm
519 (O) PSP switch/circuit open - PSP. Not sure what this means. Hmm.
*edit*did a search, and others were getting the same code and not able to start their car. Might want to check that power steering pump. *edit*
Bizzy
The power steering pressure switch is located on the driver's side, rear of the engine bay near where the rack goes through the firewall. It could be unplugged or not clean. I don't think it would keep the car from running or having spark but I'd have to double check that.
Do you have the bottom two bolts that connect the DIS on the crossover tube? If not then you need to make sure they're on there. Make sure that the DIS and the contact area are free of any dirt or grime.
Have you checked your coil pack?
Typically when a car is running prior to doing some work and not afterward it's something near where you did the work. Recheck everything you may have unplugged or even bumped when you last worked on the car.
gbizzle27
Bradford, Pa
well i worked on the pully side of the motor. So i checked the CPS, DIS and DIS ground. I am lost of what else it could be. How would i check the coil pack to see if that was the problem?
