NOS
SLOWgod
Weeeeeeeeee
Where should I tap into for a vacuum line to hook into a dry zex nitrous kit
Jordan_R
Missouri
What do you mean a vacuum line? I just put it pre turbo or @802SHO put he pre throttle body
Jordan_R
Missouri
He has a Gen 3 SHO
Ahhh, gotcha. Anyways if you are doing a nitrous dry shot it doesn't really matter where you have it as long as you are in the intake tract.
Edit: you might have to spray before you MAF so the car registers the air. Not sure how the gen3 work in here, but not trying to mislead either
SLOWgod
Weeeeeeeeee
I’m spraying after the maf and I was going to buy a 3 way to on the Evap connected on the side of the intake
E1
Crash Tested
Chicago area
Tee off the little hose going to the Fuel Pressure Regulator on the passengers side of the surge tank.
SLOWgod
Weeeeeeeeee
I got that one but there is another one you have run off the intake
E1
Crash Tested
Chicago area
Are you looking for a vacuum signal source or a port to spray INTO?
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
You'll love the Zex kit. Betcha 35 shot won't suffice. @Jordan_R we both played with 50 and 75 shot jets after we both said we wouldn't go more than 35 lol
Mashhor AlWaqdany
Jeddah
For the dual intake are you spraying 75Shot each turbo ?!
