ClaytondeG
Hi all, I have a 1990 Taurus SHO. Recently it was making a noise while turning at speed. The noise is definitely coming from the driver side, increases frequency with speed, and is worse when turning right. The noise started a few weeks ago and then suddenly got MUCH worse. I pulled over to the side of the road and my lug nuts were a bit loose and the axle nut was basically COMPLETELY loose. I added some lock tight to the axle nut and torqued it down again, put the wheel back on, and drove home. Although the noise got slightly better it still isn’t gone. I’m afraid that the lug nuts or axle nut loosen off again. What could this be? Am I just not getting the wheel tight enough? (The studs are kinda chewed up) Is it a bad wheel bearing caused by the axle nut loosening?
Here is a video of it happening. It’s a bit quiet in the parking lot, but at speeds closer to 30+ and a sharp right turn the sound it DRAMATICALLY louder.
