I am pretty much at a loss...maybe someone has some input. Ill give you a little history as well as my problem. I just recently bought a 95 SHO ATX. I have replaced my water pump and thermostat so far. I also had the tranny fluid flushed out and changed, was brown but free of any metal shavings or debree. My oil light was coming on and i had a noise that sounds somewhere between a ticking and a clacking, but it is not a knock. I changed the oil, which seemed to be rather thin. I replaced it with 10-30 weight. Someone i had consulted about it seemed to think it may have been a lifter due to the thin oil. The noise isnt constant. It usually takes me tachin' it up to like 6k, pretty hard accel to make it start. After it starts, i can shut the car off, and immediately restart and the noise is gone. It is very sporadic and most of the time there is no light on, the oil light was on constant but went out after the oil was changed. Now the light has started to flicker a little bit in conjunction with the noise. Any ideas on what this could be?
