redsho
Need 4 SPEED
All,
RE: 95 MTX @ 98K miles
I'm seeking some advice as to what is causing this sound. It's kind of a rattling noise that seems to be coming from the tranny/clutch area. The clutch was replaced exactly 1 year ago. The noise is really only audible under two conditions: heat/ac turned on & car in netreul. The noise goes away when heat/ac on, but clutch pedel depressed. Let go the clutch pedal and noise comes back on.
The first guess is it's a clutch problem, so I took it back to the shop that installed the clutch. They inspected & said it could be the tranny? However, they can't be positive until they take the tranny apart & diagnose. They also indicated that my water pump is leaking. Could this just be the cause of the problem? I do not notice my tranny having any signs of problems and the car seems to be running fine.
Thanks for any guidance!
