magnaflowSHO95
so i was changing the plate bulbs in my '95 SHO from the factory ones, to a set of LED's, now, i accidentally touched a wire to the + and - side of the factory plate light (car was off, so were lights) and i heard a spark, so immediatly i pulled out the wire and turned on the lights, and nothing happend, the headlights/fogs worked fine as well as the brake lights, but the tail lights wouldnt turn on, so i ran a test light on all the fuses, under the dash as well as under the hood, and they all tested good, im confused, is there any other fuses, or anything that would have acted like a fuse anywhere else in the car? i tested the wires running to the tail lights and they had no power also, so its not the bulbs or anything, any help would be great! thanks!
