No start after tune up
shotime1994
AirHammerAndrew
New York
Hi I have a 94 mtx sho and I just did valve cover gaskets, sparkplugs, wires, bbbs port and polish runners and 77mm throttle body after I put it back together I started the car it was running for 15 mins real nice then stalled out and wont restart I lost spark I then replaced the dis and coil pack still no spark any input will be extreamlly helpful. Thank you
Vnuk1
Mr. Mayhem
Minnesota
Did you check and make sure everything that is supposed to be grounded on the Intake is tight that has been known to be a problem.
shotime1994
AirHammerAndrew
New York
Hi what wouldnt have got grounded on the intake? and also the the intake is powdercoated white where the dis sits is also painted is that a ground for the dis or no Thank you
Ishodu
One of the screws for the DIS is a ground it shouldn't have been painted behind it. Also there is a ground strap that attaches on the rear of the intake and the path to the dis must be a good ground path.
Vnuk1
Mr. Mayhem
Minnesota
The four bolts that hold the DIS need to be tight or it might not ground. Just go through everything you see and tighten it to make sure.
shotime1994
AirHammerAndrew
New York
Also why would the car run for 15 min then stall maby a crank or cam sensor could have gone bad?
Vnuk1
Mr. Mayhem
Minnesota
CPS yes that is possible. Have you changed your Water Pump and or inspected the current one for leaks?
shotime1994
AirHammerAndrew
New York
Its not leaking but like I said the car was running smooth the just stalled like someone shut it off could the cps just break like that the car has 104k on it.
Vnuk1
Mr. Mayhem
Minnesota
With a SHO anything is possible, but without seeing it myself thats is likley to be the problem. Have you checked for codes?
shotime1994
AirHammerAndrew
New York
What about the cam sensor will that cause the car to have no spark and will the ignition switch do the same?
Vnuk1
Mr. Mayhem
Minnesota
Well is it still not running? Have you tried starting it again and did you remove the cam sensor at all?
shotime1994
AirHammerAndrew
New York
Its still not running and I didnt remove the cam sensor. I dont want to go out and spend a lot on a crank pos sensor and still have my car not start you know.
Vnuk1
Mr. Mayhem
Minnesota
In that case go through and tighten every bolt you see and try restarting. If that proves not be the cause then just replace the CPS you're going to have to replace it anyway. Again have you tried pulling any codes this will help you determine if you need to replace the CPS. CPS failure will not throw a code though but will help rule out any other problems if nothing pops up.
shotime1994
AirHammerAndrew
New York
There are no codes and I torqued every bolt and rechecked again so its prob the crank sensor right.
USHOMEISHOU
Troublemaker
New Mexico
Sounds alot like the crank sensor, when mine failed it would work until the engine warmed up and then stop sending a signal which would cause a no spark issue until the engine cooled down. Once the engine cooled it would start right up again until it got warmed up, then die again and so on. I replaced the CPS and it's been runnin fine for almost two years now:thumb:
***edit: to answer your question, yes, it does sound like your Crank Sensor.
shotime1994
AirHammerAndrew
New York
I will replace crank sensor tommorow and let everyone know what happens Thank you all for your help.
