No start after tune up
Vnuk1
Mr. Mayhem
Minnesota
More than likely just replace it and now would be a good time to do the Timing Belt and Water Pump if you have not done so already.
USHOMEISHOU
Troublemaker
New Mexico
You might try to let the engine cool completely first (like wait till tomorrow) before you buy a CPS, if you don't have a spark now but you do in the morning it's definitely your CPS.
shobote
Naperville, IL
Are you certain you are not getting spark i.e., did you hook up a timing light or pull a wire and ground it to see ? Just seems strange to have it and then not all of a sudden; may be the fuel pump has gone south if you do have spark.
shotime1994
AirHammerAndrew
New York
Yes I am certain that I didnt have any spark I have a spark tester and I had fuel pressure. The car didnt start today so I removed the dis sensor and sanded the paint off and sanded the paint where the bolts went into the intake and the car started right up I lost the ground for the dis so now the car runs mint. Thanks for input everybody.
shotime1994
AirHammerAndrew
New York
Ok will do that tommorow morning at the shop its about 7 degrees outside Thank you
haydenkayne
springfield
sanding the paint should have been the first thing you did, always remember, most electrical problems are faulty grounds
myculito
