Dr.Evil
No Dif Pin!
No start after rebuilt motor swap! EDIT#2 Its Alive!
*EDIT #2*
Got it put back together, and it fired right up! Aside from a tensioner washer being put on backwards, it runs fine. I put the thermostat in backwards, so it was not cooling (shut it down at 230). Once that is switched Ill finnish breaking in the cams, change the oil and take it for a spin! BTW oil pressure was great, around 65-70 PSI! The engine is a 3.0 bored/honed .030 over.
*EDIT*
Stupid me forgot to screw on the little brass piece that the cam sensor uses to sense the cam. Timing, both cam and spark, is right on. Still worried about the low compression. Maybe it is because the new rings have not had a chance to seat? Also, I did not see any oil seaping around the cams when I cranked it over w/ the cover off. Also, the tensioner does not feel like it is charged with oil. Do these events only occur when the motor fires up?
Alright I finally got the new motor in and hooked up. I primed the oil pressure with no plugs in the holes, and saw it was flowing nicley through the fill hole. I dropped in the plugs and wires, double and tripple checked all connecors and vaccumm lines and went to start it. I heard one combustion blast through the Y-pipe, and one backfire through the intake after I gave it a small shot of starting fluid to help it out.
Here is what I have checked:
1. Its getting fuel, all the plugs are wet and there is pressure on the rail.
2. Its getting spark at TDC and once more when not at TDC...? Is this normal?
3. Timing is dead on.
4. Compression is around 125 on the one I checked.
5. Crank sensor is working because the tach moves when cranking.
I hooked up a vaccumm guage and it is registering 0.? Also, when cranking it over, there is not much suckness when putting my hand up to the TB.
So what is it? Manifold not seated? Not properly grounded? Also, does this look right? I wasn't sure which was the inlet and which was the return:
PLEASE HELP!
*EDIT #2*
*EDIT*
PLEASE HELP!
