no power
Yamabull
England
My car has no power below 4000rpm's. You step on it and it just bogs. Any ideas. the Secondaries are closing.
AREA 91
PA SHO SHOP
Area 91
Are there any codes?
Do you feel a mis fire?
intake leaking?
Yamabull
England
no oil in the wells. No codes. IT currently has no cats and has true duals. Could there not be enough back pressure. The wires look good but they are original it appears.
qiksho
SHO Addict
Fargo, North Dakota
I would pull your plugs and inspect them. If they are not motorcraft you need to replace them. 3 out of the 4 SHO's I have bought have had the wrong plugs in them and they typically will not last 10k without having problems. I would also suspect your wires arcing if there are no codes. Replace these two items and you should be good to go. :thumb:
SASHO91
Zoom Zoom
San Antonio,TX
have you checked the blinker fluid? i have noticed alot of people have been having problems with those... :)
Yamabull
England
The blinker fluid is fine I just topped it up. It has good plugs and they are the right ones. I think I will just order some wires when I get the money and go from there.
