SHOBen
Much like another post I bought a 90 Model that was not running. It had the intake off and sat for 7 months. I have sinced put the car back together, basically did the 60k upper, all valves were inspec. The cam lobes looked good. This was all I knew about the car when I bought other than the kid telling me it would not pass emissions. After I put a new battery in it today it fired off, but has a "miss" it sounded like electronic miss, but it is not. It has brand new plugs.
My father-in-law and I thought we heard a mechanical sound coming from the front bank as you look at the cylinder bank the hole closet to the cam gear. We did a compression test it made it up to 150psi (not sure how accurate the gauge is) anyhow it leaked down on all 3 cylinders immediately, we did not do the back. I also drove it down the street it made no power, and the oil light came on just for a split second. I am not sure if the car with 66k, had ever had the timing belt or the valves looked at before. The valves being in spec lead me to believe it was, and I think the cam gear is off a notch or two and is causing the immediately leak down on the compression test. THoughts, suggestions, comments.
