The "clockspring" provides the connections for the air bag, the horn, and the cruise control. It is a ribbon of wires, for the aforementioned items, that is wound up and unwound as you turn the steering wheel from the center to the right or left, and back again. Thus it is referred to as a "clockspring", because it winds up and unwinds like a clockspring.
It is behind the steering wheel which will require removing the steering wheel, and that requires removing the air bag.
IT IS IMPERITIVE THAT YOU DISABLE THE AIR BAG IN THE CORRECT WAY BEFORE ATTEMPTING TO REMOVE IT. Do a search for the instructions on the proper way to disable the air bag as it has been discussed in numerous prior threads. If there is something you do not understand, ask before you go any further. The air bag can be extremely dangerous (even deadly) if not correctly handled, removed, and reinstalled.
IF YOU ARE NOT SURE, DON'T.
rangerj
