Lets see what we got:
19 - (O) No Vehicle Power (pins 37 + 57) or bad PCM VPWR Diagnosis
(R) Erratic idle during test (reset throttle & retest) - Idle Set Procedures
Electronic ignition Cylinder ID sensor/circuit problem - Ignition Systems
Now, time for the power of deduction.
Since you are getting codes I am going to assume that code 19 is in reference to an ignition problem. As Scott and others said, get this taken care of first. check the ground wire on the intake. I have also seen the plugs on the DIS (Gray box on the side of the intake with two plugs) come unplugged from engine movement.
21 - Engine Coolant Temperature (ECT) sensor out of range
This will not affect your no-start condition, but you do want to get it taken care of.
22 - MAP (vacuum) or BARO signal out of range - MAP
**** if I know.
24 - Intake Air Temperature (IAT) or Vane Air Temperature (VAT) sensor out of range
Again, not going to affect your no-start condition, but get it taken care of.
29 - Vehicle Speed Sensor problem
Yet again, won't affect your no-start position but could definetly cause the car to die (even when rolling) when the clutch is pushed in. The computer on the MTX uses this sensor to determine engine speed while rolling.
59 - AXOD 4/3 circuit fault - Transmissions
3.0L SHO - Low speed fuel pump circuit problem - Power / Fuel Pump Circuits
Along with spark, you need fuel and air. This code suggests that you may have a fuel flow/ pressure problem. Hook a gauge up to the shrader valve on the fuel rail and turn the key into the on position.
66 - Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
Most likely isn't causing a no start condition, but could be. This will, however, greatly affect driveability and power output of the car.
Have you ever had a valve adjustment done on this car? It looks like with some simple up keep you can free a lot of stolen ponies.
