angstrom89
On my 1994 mtx i turn my key and the fuel pump does not turn on. And there is no fuel pressure in the fuel rail. I went through the powertrain control manuel and got stuck. I have 3.5 mv at igneta switch. and at pin 5 on ircm the same. i have power going to the ircm on pins 8 and 12 of 11V. i tryed diffrent ircm i still had nothing. the book says to test ircm and cheak voltage at pin 22 then go back to the first section of flow chart. does it mean the pcm because on pin 22 on ircm is WOT A/C cut out. and how many volts should it be and if there is or are not any votage at pin 22 on pcm what is wroung and what to fix. If any one could help id very much appreaciate it.
