Question... 92 mtx ...... runs for awhile then it looses fuel pressure and dies. Has gas, Cannot hear the pump cycle when the key on. I have switch out the CCRM and it is not that. I have cut the hole in the under the rear seat to expose the fuel pump. I hooked up a fuel pump of one I had laying around and it does not cycle either ( it is not installed, just hooked up the connection to test to see if it is power to the pump problem) Should the pump I have hooked up cycle if it is getting power? If it should then I have a problem somewhere else and it si not the fuel pump... Any ideas?
