No Dash Lights After Deck Install
MilTownSHO
Horicon, WI
All my other lights still work fine but my dash will not illuminate. The turn signal lights, high beam lights, airbag, etc on the dash all still work though. I looked in the owners manual and there is no fuse for just the dash. Any ideas? Thanks,
Jason
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
There is a wire that the factory radio uses to dim that radio with all the other dash lights. When you put an after-market deck in, it doesnt use that wire anymore (you can dim an after-market deck) that wire may have grounded out or something. I would pull out the deck and, using electrical tape, tape up any loose wires that the new deck doesnt use. Then check, replace if needed, the fuse out of the fuse box by your feet when your sitting in the drivers seat. (owners manual tells you which fuse it is) Then you should be good to go! thumbs_u
