New SHO owner questions
shobikes
ashevegas nc
Hey y'all-
I picked up my first SHO back in Dec. A clean '89 with good service record. It has clutch upgrade, and the first 60K was done. Now has just over 120K. I am planning to do my own 60K soon. Yesterday I yanked intake manifold & cleaned it and IAB valve (Thanks SHOtimes!). Also pulled & regapped plugs, retensioned timing belt, had a good look at timing belt/thermostat/valve cover gasket job. Seems I could get it done in a day, if all parts & tools on hand.
So I'm hearing stories of rod bearing problems and the diff. pin horror. How do I check for these things? Is rod bearing inspection simply mandatory? Can it be done from below, w/o removing engine? Should I just get the parts and do it ASAP?
How can I check this diff. pin problem out before something horrible happens? What's the fix?
What other issues do I need to put on the list as a new (old) SHO owner?
My car runs like a bull - burns very little oil, no sign of valve stem seal leakage. I think most of my oil loss is into plug wells! Those things were full to the tops of the plugs!
One last thing - my car seems to have a partial-throttle surge, around 25-2800 rpm, esp. when A/C is on - is this normal? Will new K&N (bought not here yet) fix this?
OK - time to help the newbie. Pile on the advice!
<small>[ August 24, 2003, 09:14 PM: Message edited by: shobikes ]</small>
95SHOdude
Houston, TX
Fix that oil leak in the spark plug wells. Oil on plugs=misfire. Since you pulled the intake just keep going and pull the valve covers. Search the links for the gaskets and procedure. The bearings are simple to do also. Good luck and enjoy your SHO.
