New Radio installed... intermittent NO Start Issue
CrispySHO
Orillia
Well, the title pretty much says it all.
I used a Taurus Radio Harness, And an AMP bypass kit, I wired it all as directed and then about 15 minutes then died, now it seems that it likes to die intermittently, or not start at all... also.. when it is running if i switch the headlights on the car dies...
Is there anyway i could have dislodged something behind the radio that may cause this?
Or is it all the Cranksensors fault?
I get no codes.. and the tach does go to 3-400 when cranking.
weird huh?
Thanks for any help guys.
audioman
Morton IL
You are going to want to pull the radio out and make sure no wires are touching or have become disloged and check the fuse box under the dash to see if any of thoes have gone out. One other thing make sure your dimmer wire to the radio is hook to the right accesory wire if not you could be getting a problems when you turn on your lights. Thats all i can think of right now.
dan.delargy
