New Problem - Hood Latch Won't Open Hood
SHOLUV
TX
The latch that pops the hood on my 97 doesn't work and I can't open the hood. Is there any other way to open it?
SHOsFAST
Who's Running?
Colonial Heights, Va.
You might be able to get to it from underneath the car by pulling on the cable itself by the latch if you can reach it that is I have a gen 2 so I dont know about a gen 3, good luck.
98TRSHO
kalamazoo
after our car was repaired in the front end we couldnt open our's eather. I ahd to pull the release lever inside while Tim forced it up enough to pull the lever. when I was alone and just kinda banged on the hood where the latch is, that worked half the time.
Good luck
SableSal
SHO-ABLE Owner
Fresno, Ca
Once you have it open, **** the latch assembly with some lithium/wd-40. You should be good from then on.
If you adjust the latch down a bit it will apply enough pressure that when the cable releases it, the hood will pop up with authority.......:type:
