americanmotorsport.com
I need an EEC code...and I'll check if I can come up with something.ncmcn:
How about a 2002 Jag X-Type 2.5l 5-Speed? naughtyamericanmotorsport.com:
...and some limited Jaguars.
We've had Apten, and now American MotorSport. I think the others may have been before my time there. Apten is still a supporter, although I have not heard from Brian in a while.Especially on Bob's forum (taurusSLOcarclub.com). First it was Superchips, then Diablo, then Fordchip.com, then Apten and now your company. I've yet to see positive proof that any of those chips made horsepower. $300 is a lot of money for no gain.
I'm guessing experience.americanmotorsport.com:
What do you think would be so different about a stockish car that would MANDATE live dynotuning?
UMMM how about no. I have done several of these, even via mail order. The EEC is the EEC, it has nothing to do with the "complexity of the motor." Number of cylinders, displacement, and firing order, etc. are just values within the EEC. If you knew more about tuning you would know this. If someone is "really good" at tuning say Mustang's but not SHO's, then it means they don't know what they are doing. For Mustangs, someone once got it "close enough" and they all use that with small changes for each car. I do get OEM driveability and have the ability to make changes most can't. Diablo and them have the ability to change like 60-80 parameters in the EEC, I can change all 3000. Even for an N/a stock car, I change like 300. Clearly that would make a difference.Ian Macoomb:
I think you under estimate the complexity of the SHO motor. Kirk has spent tons of money from many different companies and none have delivered proven power and reliability.
Basically what Kirk is saying is put up or shut up. We've seen claims like your before.
I agree it is best, for heavily modded cars. I can send you a chip and you can dyno, then send me back the feedback and I can tweak. But they way I do them, I always skew rich to err on the side of safety. Sometimes though, a correction isn't even needed. I have made many high-HP cars run right this way. I am never more than 10% off unless the car has issues, inadequate fuel system, etc.Yamaha V6:
Not to be a **** on someone else's threads, but my official position is not to make a major air/fuel adjustment component installation (chip, MAF, etc.) unless it's done on the dyno. It's just too dangerous.
We've seen the same 80mm MAF & chip (granted, on the V6's), with the same year, trans & LPM run correctly on one '95 MTX SHO, and run 18:1 on another '95 MTX SHO. My point's not to "prove" the power as much as it is to ensure the car's not going to go lean with any of these modifications. This is why I believe every chip should be at least a 2-step process:
1) Burn to the configuration
2) Dyno Test, report back the findings including a/f, and make the determination about any further adjustments that may be required or desired.
Without that second step, it's a crap shoot. I received in an LPM from the west coast which was programmed incorrectly (heavily modded 3.2L MTX w/ the bolt ons, and it was flashed for a stock X2J); mistakes can happen. Everyone here on the board likely knows about the other tuners, who've been doing the SHOs for years. I dyno test with those chips as well, for obvious reasons.
Don't get me wrong, I'm not bashing Alberto or his programming ability, I'm just voicing a personal opinion that any component like this should be accompanied by a visit to the dyno, unless you've got a real air/fuel setup like Josh T does. Power numbers are a great byproduct of making sure there's not going to be a SHOBoom, or a worthless decrease in gas mileage.
