I bought a used 1998 SHO V8 with 180,000 miles on it that was maintained well. The cam gears welded, all service bulletins done by Ford. I had the AT removed and completely rebuilt by a local shop (LA area) that does this a lot due to engine shifting issues. The car runs well but has hadthe "oil pressure" light come on and flicker after exiting the freeway and sitting at a light. Oil level OK, run synthetic 10-40. Thinking of dropping oil pan and renew bearings. Is there an oil pump upgrade for the V8?
Are the con rod bearings readily available? What about any gaskets? The oil pan is a "sealant design" for sealing but not sure about the oil pump and oil screen-any advice?
Fred
Fred
