new crankshaft postion sensor 89-95
I was told by NAPA guy local they can't get it. I would try and order one online just in case. They can always cancel your order.
zoomlater
Seattle, WA
I wonder if there is another Ford CPS that could be modified for the SHO. The mustang/ranger version from that time frame is similar
https://www.ebay.com/p/ABS-Crankshaft-Position-Sensor-F27e6c315ba-for-Ford-Mustang-Ranger-B2300-BT/6022213993?iid=163188584756&_trkparms=aid=555018&algo=PL.SIM&ao=1&asc=20131003132420&meid=baf526b8531044b49aa31c806fa36ded&pid=100005&rk=2&rkt=5&sd=162219061796&itm=163188584756&_trksid=p2047675.c100005.m1851
This looks closer, it is from a Thunderbird SC, length looks shorter. These cars were a limited run as well, so they may have the same issue
https://www.autozone.com/engine-man...duralast-crankshaft-position-sensor/68787_0_0
I was thinking about that when I realized these things were running out. There has to be a way to rig up something. Like using one of those and splicing in SHO wiring if needed or something.
zoomlater
Seattle, WA
For the price of these, it wouldn't take much to buy one so they can be compared. The question is do they output the same signal that is needed. Is anyone familar with the Ranger 2.3L engine from 93/94?
zoomlater
Seattle, WA
Amazon is showing one vendor with this part number
Borg Warner CSS54 Crankshaft Sensor
tompumped
VT
Yes I saw that. I went to that sellers website to see how much they had it listed for and it was way less but it said out of stock. Hopefully someone can make this work with one of those two sensors. I guess you'd need a scope to confirm it or just try it and see what happens.
The one from the thunderbird sc may put out the same signal. I guess you could look up the diagnostic flow charts for testing the crank sensors and see if they have any values that can be used for a resistance test.
tompumped
VT
The thunderbird uses the same camshaft sensor so this should work, but they seem like they are unobtanium as well.
zoomlater
Seattle, WA
On Zach (Blue Turd) Facebook page, it looks like he used a MOTEC hall effect crank sensor on his car. Anyone know any more about this set up?
tompumped
VT
for anyone interested. I just learned something invaluable. Tefzel manufactures wiring for aircraft it meets their specifications and it's the same price as normal crap wire i've purchased for years. They make shielded single, double and triple pole wire. The ground wire on our cps actually just connects to the shielding.
There is also a company called techflex. They make flexo tightbraid which is a unique and different type of wire loom. It also meets avionic specs.
I recently purchased some of this style wire loom after seeing it on equipment at work. Strangely enough the day after I purchased it I was chasing wiring issues at work and I found out that it had rubbed through in various places on the machine. I don't believe it's as abrasion resistant as the normal corrugated style but this brand I just found may very well be. It is made with much thicker monofilament and it is a very tight weave. I'm going to try it.
With heat shrink on the ends it looks very clean. The image is just for reference, I wouldn't use it on hydraulics the only thing that lasts on our equipment is a very heavy cloth braid made by eaton.
tompumped
VT
I wasn't going to say anything but last order I placed ended up getting refunded because it didn't ship for three weeks or longer. I read the shipping disclaimer.
It happened to other people on here also.
zoomlater
Seattle, WA
IMG 5505 The length of the wire of the Ranger CPS is longer than the SHO
The gray connectors appear to be the same, but the black connector alignment guide is different so that would need to be swap
The wires exit the back of the sensor in different locations
The thickness is slightly different but could probably be modified
I am not sure where the sensor is located on the Ranger CPS. Before I cut it apart, does anyone know what the differences were between the Ranger and Mustang or which gap (upper or lower) the vane passes through.
zoomlater
Seattle, WA
From what I can find on the internet and cross checking the SHO EVTM manual, the signal into the CPS appears to be the same (different terminology). I am going to try and cut off the bottom hat section to see if there is anything in there.
zoomlater
Seattle, WA
There is something metallic in bottom hat section. More research...
ribeye2065
