zacritz929
slowSHO
As some of you might know i just did my front 60k and then found that my cam sensor is bad so I changed it but Im still getting codes 212 and 214. I made sure that the pins on the new sensor are fine. How do I check the female pins? Also I noticed that there is a burn hole on the surface of the female connector. It doesnt look like it burned through or anything but is this most likely the problem? If so where can I buy a new connector from?
I heard that if the CEL light goes off when I try to start the car, it rules out a bad Crank sensor. Is this true?
The car wont even start now!! Help please!
