If it has an aftermarket security system that prevents it from starting, then the starter **** probably breaks the ignition circuit. You'll have to rip out the brain of the alarm system and try to piece back the wires that should mate to each other w/o the **** switch in place. Depending on the alarm, sometimes there will be a button that you push to defeat the starter **** and it will allow the car to start. Such **** switches can be under the dash, or concealed by the center console. I hid my **** switch on my '73 Charger by replacing the hot on my cig lighter with a ground that would complete the circuit so I could start my car. I always had to have my cig lighter pushed in (like it was energizing to light a cig) until I parked it and wanted to engage the **** switch, at which point I'd pop it out like 'normal'. If someone would try to start it, the car would crank and crank but not fire.
