SW SHO
Boss Man
This is a typical story of either leaking system, and ill trained mechanics. Anyway, I took it in for testing, pressure, leaks etc, and was told the compressor needed replacing.
I was skeptical because I could hit the a/c clutch and it would engage but wouldn't stay engaged for more than a few minutes. Well, I know the owner of the dealership (Mazda) and his tech replaces the compressor and clutch, recharged.
Well it's blowing cold again, cycling okay for about a week, then I'm at a drive thru with the max a/c on at 60 degrees and the systems stops cycling. It wasn't really trying to cycle either, then I get on the highway and it's fine.
Is this a switch at the compressor problem? I also notice when it's cycling and I'm cruising at low speed I can hear like a spinning sound, much louder than before the replacement.
I really don't want to take it back to him to check, because I first wanted to convert to 134a and there tech on the advice of the Ford Dealer tech said "this year/model Taurus couldn't be converted" bs of course, I printed out the write up with pics from Shotimes from an 90 or 91 IIRC.
The guy is giving me a deal, all the labor and R12, new compressor for $250.00, but if it isn't done right then it's not really a deal.
Advice?
Advice?
