Need the wiring harness to hook up an aftermarket cd player.
ACV1081
Member #187
IA US
I need the wiring harness that allows me to tie into the jbl system in my 91 cause it has a tape am/fm plus it isn't working right now. I'm thinking of a cheap aiwa mp3 player just to get some music in there. Where can I get the harness & is there anything special I have to do to tie into the jbl? Thanks in advance.
The fleet: 1012264997459 123
~Adam Varney~ mailto:[email protected][email protected]</A>
1993 RED ATX(3 replacements) W/shiftkit, 130,000 miles(Fresh 60/100K THANKS SDPATT!), 17" Konig Reigns, 245/45/17 Goodyear F1 Gs(Summer), 225/55/16 Blizzaks WS-15's on slicers for winter duty, 26mm ASB w/poly bushings, Tweaked stock airbox with K&N panel filter, D4U1 computer, blazertech fogs, & performance friction brake pads, SHOSHOP Stut tower braces(front & rear). GTECH times 0-60 in 6.92 1/4 15.3 @ 98.4.
Not yet installed: 24mm ASB(spring), & rest of the poly bushings... Upcoming: Well you could just say I am on hold since I bought a gen.1 now.
New to the lineup: 1991 White MTX- 122,000 miles, recent 60K & clutch, K&N filter, rod shifter, dynomax catback, SHOSHOP y-pipe, & white slicers w/ 225/50R16 Dunlop SP Sport 8000 tires. Too bad she'll be sitting till spring cause I'm not driving it in the salt & sand. Website with pics from previous owner: http://www.homestead.com/SHOIOWA/SHO_Spring_2001.html
RickieFrat
La Cosa Nostra
State of Corruption - RI
Your local audio shop should be able to suply you with a Ford Low Level & Amp By-pass cable wiring harness. If they use Metra Install kits the Part # is 70-5514. The price should be around $30.
Just color code the wires together and plug in the clips to the factory wiring. The amp by-pass could be/couldn't be used .... depends on the sound of your liking.
On wiring up the radio. Make shur you connect the power antenna AND the remote amp turn-on (blue/white chaser) wires together with the Accesory turn on wire coming out of the radio. This will turn on the JBL amp AND raise your antenna.
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
ACV1081
Member #187
IA US
Rickie can I buy this from you & what bout on a 91 where the antenna has the up & down buttons? I really wanna get all this done for less than $175... possible? Thanks bud.
RickieFrat
La Cosa Nostra
From what i'm told you will still have that function available.
One thing I do know is the radio that Eric is selling has the wiring harness included. Just a simple install of the radio sleeve, plug in harness, slide radio in lock position, and play.
If you want just the harness you can E-mail me off the forum at .... [emial][email protected][/email].
ACV1081
Member #187
IA US
Damn the Rickkie/Eric duo is quite a marketing pair
Shoot me a price at my email for your JVC Eric... I'm not a big fan of that brand but if I can get a deal then hey. [email protected]
Schiv1010
