Need some help
Gianni
Worcester, MA.
I brought my car in last week for the check engine light. The said it was some sort of hose and they replaced it. Only $60. When I got the car back it would run fine while moving but when I came to a stop it would idle rough and then die. I brought it back and they said it was the o2 sensors. I just got my car back and the problem still isn't fixed which I realized whe nI got to work. Does any one have any ideas before I bring it back? I was thinking maybe the fuel pump but I really don't know. TIA.
JaySHOguy
Bellingham,MA
Gianni,
Take your car to a local AutoZone. They will read the codes, and you can find out what is wrong. To me, it sounds like you have a bad coil(or on its way out).
Good luck.
Gianni
Worcester, MA.
Jay, thanks for the autozone tip. that may come in handy in the future. Actually they fixed the check engine light problem. This problem isn't throwing a code. And it better not be coil because I just replaced them. The dealership has the car now so I will keep you updated.
DavidT
TN
doesn't the computer "store" codes? Have Autozone check it.
