MerkXRTurbo
I just got a call from a friend who has a line on some 5 speed SHO parts, and I want to convert mine. Let me start by saying that I do have the PDF explaining the process, but I'm not 100% sure on why the 3.2 is mounted in a different location than the 3.0. The only thing I can come up with is that the distance from the input shaft to the axle shafts is different from auto to manual. Is this correct?
Why do people swap out the subframe? I've got decent welding and fabrication skills. Would it be easy to modify the mounts and stick with the ATX sub frame?
No possibility of using 3.2 accessories?
I know that these are usually the types of questions that if you have to ask the project is out of reach, but the only reason I'm asking is because I haven't had a chance to make a close up comparison of parts and engine bays.
