Need Serious Help
SHOracer86
Florida
I leave for training on Sunday and of course the 91 SHO decides to act up. I changed my plugs due to a stumble at idle, muffled sounding exhaust, and slight bucking and it fixed it but now its back. I have denso iridiums in it. I ran the codes and got this : at first 11 then 14, 29, 63, 66. KOER: clear.
I am having severe bucking problems now and a incredible loss of power.
Please help
NP SHO
Rice Killaaa
Windsor, New York
11 System checks OK -
14 Ignition pickup was erratic - Ignition Systems
29 Vehicle Speed Sensor problem - VSS
63 Throttle Position Sensor (TPS) signal too low TPS
66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
Transmission Oil Temperature (TOT) signal low (possibly grounded) - >Transmissions
The link posted previously will bring you to the main site, but the link below will take you to the page with the code definitions.
http://www.shophoenixproject.com/eec/code2.htm
Hope this helps and good luck!
SHOracer86
Florida
Ive swapped out the tps and maf for another one i had and the probems are still there. Cam Sensor?
my first guess would be a wiring issue on the left side of the engine - many of those sensors are on the same section of wiring - I'd look that over very carefully to ensure that the ground is properly connected for that section of harness.
