need quick help with engine brace for clutch replacement!
SHOpride
Chicago
I used the search function but i couldnt find the answere to my ?. I have an engine brace built so i can drop the subframe, but don't know where to hook up the chains on the backside of the engine. Thanks very much for your replies. Sorry i posted this in the wrong forum.
sideSHO
East TN
Search for "sdpatt engine brace".
He has a really good write up on what he used.
I think the bolt hole that holds the intake brace is used on the right rear.
Ishodu
On the back side of the rear head throttle body side there is a hole you can install a M10*1.5mm bolt or stud in there. You will see it when you get under the car and look in the general area.
SW SHO
Boss Man
Santa Fe, NM
Engine support details: Sticky on this thread.
http://www.shoforum.com/showthread.php?t=9138
I built mine from SDPATT measurements, worked great. I didn't use the metal bracket shown between the rear support chain and head stud; just put plenty of shop rags between the chain *** the head/valve cover.
Remember if your support is a once piece type to make the eye bolt hole left of center over the engine to create a little lean of the engine toward the drivers side...makes removing/replacing the tranny much easier.
SHOpride
Chicago
Thanx for the quick replies and help! I was able to remove the subframe and the engine is well supported.
