Need more description on codes
marvsho17
Joshua S.
rockford, il
While getting the low coolant light because of a leaky water pump, last night I got the good ol cel.
21 - Engine Coolant Temperature (ECT) sensor out of range
25 - Knock sensor not tested (ignore if not pinging)
73 - Rerun test if 73 is still output replace TPS No Throttle Position Sensor (TPS) change in "goose" test. Must get at least 25% throttle rotation
91 - System running lean Transmission SS 1 circuit/solenoid problem
The 21 25 73 aren't making me nervous, but what is this 91?
Rockledge
Pluggin' away
Connecticut
Code 91 means your left O2 sensor is indicating a lean condition.
Could be a bad 02 sensor (or a problem with the circuit), but it could also mean the engine is running lean on that side, in which case the usual suspects have to be considered (vacuum leak, fuel delivery issue, etc).
projectSHO89
SHOless In St L
If you did not pre-heat the cats, you will get a 91.
The other codes appear to be due to an improperly executed goos test. The 21 is probably due to a failure to have the engine at operating tep.
Steve
