Need Ideas\help.
SHOsFAST
Who's Running?
Colonial Heights, Va.
Hey everyone, more problems here...Mmmmmk my SHO(93 ATX) has been pretty sluggish in the low and and doesn't pull that great after the secondaries either. She stalls if I stomp it from a stop and there is no CEL. My fuel pump is also kinda loud, meaning I can hearn it on when the car is running it's sounds like a groaning noise from the rear. as far as the stalling and poor performance is it just time for a tune up? The car has 96,000 miles on it.Thank you in advance for any help.
jedhead
westminster,ca
Pull you codes so you can figure out where to start. www.shotimes.com has all the info you need to pull codes with a paper clip. Once you get the codes come back and we can help with the diagnostics. So many things can cause the problems you are having and you can spent hundreds of $$$ if you are just guessing.
Bob
ohfosho
ontario SHOwner
ontario, canada
plan on 60 k maintenance, and a good intake cleaning will bring some bawls back to your baby! also the fuel filter shouldnt be ignored. if your fuel pump is loud, it could be the cause too, although many go on for quite a while with a louder pump, with not many issues. you can do a search on how to check your fuel pressure. that will tell you how bad of a job the pump is doing.
